transmission cooler size???
Front U-Joint part number???
Brake/Rotor Heat Question
I am considering putting a larger transmission cooler on my 95 auto and was wondering about the size difference in the lines? The new cooler has 3/8 inch lines and the old one has larger lines (not sure what size). Will the new one cause a restriction problem. I am going to switch to synthetic fluid at the same time i change the cooler and later when greenbacks are more available i am going to deeper pan on transmission. I am more worried about restricting the transmission fluid and causing a pressure problem. Any help would be appreciated, thanks.
cooler size
I would recommend looking into using an engine oil cooler for a replacement as many of them use 1/2" lines and you would not have to worry about restriction. Fit as large a one as will fit in the area. Good Luck. Let me know if I can answer anything else.
James
