Transmission Cooler??
engine hiccups at high speeds
Help...Front Crank Seal?
I just ordered a #8 TST plate for my 2500 97'and all the guages. I pull a 24" TT that weighs about 8000 lb. s loaded. I am planing to travel to Yellowstone from Long Island at the end of July and I'm wondering if I should replace the stock transmission cooler. I know I have the plastic quick connects that need to be replaced and I think I will locate the temp probe in the metal line that runs to the cooler with a compression tee. I have read many different posts about the cooler, and the lines, and need to know which is the best way to go. I also plan to switch to synthetic ATF. Do I need a deep pan also?? Any suggestions??? I just don't want to get stuck on my vacation.
Barry
97'2500 4X4,AT,ExtCab,LWB,2000 24'Nomad TT
Definitely replace the fittings on the cooler, the cooler should be fine. As for the pan, if you can swing it, it would be a good opportunity to install. You can make it without the deep pan with the load you are towing and pass a few power strokes too. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 110 gal. aux. fuel tank.
LI Camper;
Dodge makes an auxiliary transmission
cooler that mounts behind the cab on
the frame, drivers side. As I recall
they run about $300. 00 and are supposed
to work real well. They are controlled
by a thermostat that can be set to
run "automatically" at a set temperature
or manual from a switch on the dash.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
To L I Camper: Since your post did not show an email address I wanted you to have this info. BD makes a auxiliary transmission cooler with a fan and lines that comes on and off when needed. Worked great on my automatic.
Mike Johnson
Ok, maybe I'm lost but are the plastic parts on the transmission or on the lines that connect to the aux cooler by the radiator?? I definitely see plastic on the quick connects up front but at the transmission I see regular compression stuff or flares (I didn't take it apart). #ad
Barry Kaminske
97'2500,Forest Green 4X4,AT,ExtCab,LWB,2000 24'Nomad TT
My '95 had quick release near the transmission itself. I don't know the '97 specs. You may have compression fittings at the transmission, but I don't know of a simple replacement for the cooler ends of the lines. I replaced all of the lines and fittings. Not cheap, but I feel better!
'95 2500 SLT ClubCab, automatic, 3. 54 LSD
Mine had the plastic p. o. s. connectors up on the oil to water cooler on the passenger side of the block. You could get little hose clamps and put them on eack side of the connocter and tie wire them together, also.
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps-Tuff Country control arms-2" coil spacers
