Around Issue 33 I reported tests on HP drag of different fluids. I found for keeping the trans temp low, and low drag, either Castrol Syntorq or Torco RTF was best. I like the latter because it doesn't seem to degrade and make black slime like the Castrol, and with a GL6 rating, should protect ther gears from breakage better. It does not attack the brass parts, unlike some GL5 and GL6 rated oils.
