While towing about 7,000lbs in stop and go the transmission gets to about 250 and puts the transmission into limp mode. Any idea how to keep it cooler?
Thanks
Thanks
tractorface said:While towing about 7,000lbs in stop and go the transmission gets to about 250 and puts the transmission into limp mode. Any idea how to keep it cooler?
Thanks
Hahn007 said:Hmmmmmmm... ... ... ... ... ... ... . I installed the BD X-monitor with a transmission temp reading, boost pressure reading, and exhaust temp reading. It simply taps into the factory (variable resistance) sensor that controls the idiot light for trans temp. My converter is also very tight, about 400-500 rpm lower stall speed than stock, and I only see about 128 deg while cruising on the freeway and if I really abuse it while towing in town I might see 140 deg. As soon as I get into lockup the temp comes right down. If I remember correctly the manual that came with my X-monitor said when using the factory sensor location to monitor trans temperature, the temp should not exceed 200 degrees. It is either 200 or 250 degrees, I can't remember for sure. The external cooler attached to the radiator is not the only cooler in the system. There is also a shell and tube heat exchanger mounted under the exhaust manifold that cools the transmission fluid as well.
