These transmissions are at and beyond their limit with STOCK power. Adding ANY power enhancer or changing the TQ management will find the weak points, usually quickly.
But mine is completely stock.
I would almost be willing to bet this problem would have still occurred if I had never done the deletes.
I totally understand what you are saying, but I don't think the smarty had anything to do with this particular failure. When I did the service 3500 miles ago, there was no indication of any sort of a problem. The pan was very clean. I think something failed internally and caused this. Not disputing you at all. Everything was perfect one moment and devastation the next moment. Wouldn't I have got a little warning if the power adder was the source? I am just speculating.Doesn't matter. Even in stock form the trans is not up to the TQ the engine can produce. The TQ management is far from perfect in all conditions. You can break these transmisisons with stock power.
The deletes are not the problem, the Smarty is. Even on the economy mode the TQ management has been reduced and that is the trans killer. You can drive easy all you like but the TQ is there and it will eventually cause issues.
Again, these transmissions are BORDERLINE over powered with stock power. Adding ANY mods to power will increase the chances of breakage, dramtically. Driving it hard stock is going to stress it also. The planned obsolesence from the factory makes it a given.
Have a friend with a 2010 with same symptoms. His threw these codes today, P0944, P0868 andP0841. Can anyone help identify these. I am searching for a list now, have seen discussion on these before but I have never had any problems myself and never had to find any. I know they have been some printed in the magazines too. Hope it is something simple for both of you.
Additional power calls for other supporting up-grades-note the 2013 with additional power get a different trans... ... ... .Thanks diesel lady for the info. Since this has happened, I have kinda got a little discouraged with the truck. Been thinking about just selling it. Not sure at this point. Now I will always have the fear in back of my mind of it going out again. I thought this transmission was better than this. I give thumbs down now to the 68 RFE.
We easily forget with all the computerized controls on our engines and trucks that large eighteen wheel trucks loaded to 80,000 lbs. and more a few years ago had engines that could not produce the horsepower and torque our quiet, smooth, and refined engines do without even the slightest puff of smoke.
The Cummins engine is capable of shredding any of the transmissions Ram hangs behind them - Mopar six speed, Aisin six speed, or G-56.
That's not the point. The point is,,,,, EVEN A STOCK engine, is more than the 68 can handle. Never before have we had a trans that had a controller that purposely down shifts and unlocks the converter so that your driving the Horsepower, instead of the torque. The REASON IS,,,, Because they knew this trans can't handle the torque, EVEN A STOCK ENGINE!!!We easily forget with all the computerized controls on our engines and trucks that large eighteen wheel trucks loaded to 80,000 lbs. and more a few years ago had engines that could not produce the horsepower and torque our quiet, smooth, and refined engines do without even the slightest puff of smoke.
