Hello everyone,
It took all summer (mainly waiting on parts as we discovered we kept needing more) but my boyfriend and I finally got my transmission rebuilt. We followed the rebuild book to a T.
Little bit of back story: in June we noticed I was having issues with 2nd gear so we decided to do the 2nd band adjustment. We did the adjustments and went to take Pig (that's my trucks name) for a test drive. We needed grease so we decided to take her up the road to the parts store. Got to the parts store and she wouldn't shift into park and 2nd gear was still slipping. Thus, prompting the removal and rebuild of my 48RE.
Bought a rebuild kit and realized that it didn't come with everything so we started ordering the parts we needed. We upgraded and put some billet parts in the valve body, but during the rebuild we noticed that the transmission was built for gas, not diesel.
Fast forward to today:
We finished buttoning her up, plugged everything back in, refilled the coolant, transmission, oil and started her up. Took her for a test drive and there is a indescribable sound coming from underneath. She also seems to be starting in 3rd and not shifting. And she has almost no power. Was pedal half to the floor to get into my not very inclined driveway. Attempted to manually shift and it does nothing. Came home, plugged in the code reader and got codes: P1749, P0973, P2769 & P0868.
I've looked all 4 up online and the most common denominator is bad PCM/ECM.
There is still a tuner under the hood but it was disconnected when I bought it. Attempted to hook it up but no dice. Seems to be dead.
2005 5.9L 4-Wheel Drive 136K miles
Airaid cold air intake
Billet servos
New Governor pressure sensor
New radiator
New power steering pump
Upgraded 2nd gear band
Also, I've checked the fuses and relay's and they aren't blown and are getting power.
Billet servos
New radiator
