Transmission issue
2016 3500 68rfe replacement pan or filter kit isn't correct
How to manually lower drivers seat!!! Help
RWherley
I have a friend with a 93 W350 with the getrag 5 speed transmission, she's currently stuck in a parking lot in El Paso Tx. and says the transmission is stuck in neutral and won't go into any gear at all. Any thoughts?
Ok I had her do some test and figured out that some how the transmission is still in 1st but the shifter has jumped out of the shift rails in the transmission. So she can't change gears, so the next question is, is there any one around that area that could fix that, or at least put it back in place to nurse it to a good shop?
