I not an expert to say the least on automatic Transmissions, but I need to leaned about the kick down settings. I done some readings on TDR about this topic only to confuse myself further. So here is what I am dealing with.
A rebuilt and beefed up RE48 with about 60k miles. Transmission heater removed, lots of 90 degree hoses removed gone, check valve remove from cooling line, BD double stack 5/8 trans cooler thermostatic w/fan, deep transmission pan, extra 4 quarts of fluid. unloaded truck internal trans temp at 85 degrees out side temp 154 degrees , pan temp 130.
Just replaced the the "throttle valve cable" aka kick down cable. I set it with the lever moving at 3/8 of an inch instead of 1 inch. Is this a good or bad setting, Too much? Truck shifts more even and down shifts better.
So am I doing any damage?
Thanks
Kyle
Thanks
Kyle
