thanks rr , i'll check it out .
john p , mine definitely was slipping , i was chasing a 2-3 shift problem , WOT everything on and the trans shifted into third ,held for about 2 secs ,then i thought it was going back to second and i lifted , after really thinking about it and staying in it longer the tac was going right to 3500 plus , the trans was in third , but no bite of the clutches . i pulled the ez , pulled the hx40 , only used my PE for a boost module with the dd3's and no one else drove the truck but me , the couple times i did tow , even an empty car trailer i have to drive it like there was an egg under the throttle . you could see the telltale signs of glazing on the steels from slipping and the clutches were very dark but still had clutch material . my tc paint looked as good as the day i installed it so no overheating there , going to miss the 93 as i go back to a 91R
kevin will do , not sure where exactly we are staying but i'm thinking it will be close to denver .
stake sorry for hijacking your post .
