I've been into my transmission more times than I care to remember. I don't think I'll ever fully understand the internals of the valve body, but I'm trying. I have a question for some of the transmission gurus out there.
What is the reasoning behind grinding down (shortenting) the shaft on the TV valve. I was trying to figure out the TV circuit today. The only reason the shaft would need to be shorter is if the kickdown valve completely compressed the TV spring and the two valves touched. What are the tradeoffs and side effects of shortening this shaft.
Thank you!
-Chris
'94 2500 4x4 auto w/ DTT TC and VB, TC saver, Diamond B 370's, gov spring kit, modified AFC spring kit, high flow delivery valves and other pump modifications, Jardine 4" exhaust, stock turbo and intake.
Thank you!
-Chris
