I took her on a second test, this time the trans was at 200*, after driving all over SoCal at 100* ambient without the cooler running. The test was to climb Cajon pass with the trans cooler running continuous for the entire climb, then run flat for a few miles then descend Cajon pass. It was impressive, from the 210 to the 15/215 junction, the start of the pass, the trans temp climbed to 215*. Here are the temperatures as I drove with the cooler running continuos until the last report.
The Climb
Trans Temp / Ambient Temp / Location
215* / 97* / 15/215 Junction
195* / 94* / hwy 138 Under Pass
189* / 90* / The Summit
Flat Running
182* / 89* / hwy 395 Under Pass
160* / 94* / Victorville ( Roy Rogers Exit) turned around
162* / 89* / Summit
The Descent
155* / 89* / hwy 138 Under Pass
146* / 92* / 15/215 Junction
I only had one rise in temp and that was due to a slight climb from Victorville to the Summit. I wanted to run the Cajon for a second pass to see what the temperature would run at with the trans temp at 146*, but it was late and the ambient was cooling down. Besides, I was going to have to get more fuel so I ended the test and turned off the cooler. As I drove the slight downhill run from the 15/215 junction, my trans climbed in temp ever so slowly indicating that the oil had cooled the trans as well, not just cooling the oil.
The Climb
Flat Running
162* / 89* / Summit
The Descent
