On two occasions I have had this light come on when my transmission oil temperature gauge is indicating less than 150 degrees. It only happens when I am putting a load on the engine/transmission while backing up my fifth wheel on a small incline or towing my fifth wheel up my driveway, which is short, but steep. The two times it has happened, I probably haven't had the engine running for more than 10 or 15 minutes and the light goes out fairly quickly once I stop and let the engine idle in N. I might mention that I have a Mag-Hytec transmission pan with the oil temperature probe locateded in the hole they provide. How hot does the transmission oil have to get to bring on the Transmission Oil Hot light and where is the factory probe located?
