Engine/Transmission (1998.5 - 2002) transmission pressure
Engine/Transmission (1994 - 1998) Timing pin
2nd Gen Non-Engine/Transmission HELP... Spongy brake pedal
first things first
First you need a gauge to KNOW what the pressure is at this time. Then you can count the turns to raise pressure a bit. The amount the pressure can be raised is controlled by the regulator spring in the unit. A given spring has a range it works in determined by length, wire diameter, spring rate, etc. HTH
James
