I bought this truck new in ID and have over 93000 miles on it with no problems. I have done the mystery switch and have installed a Pac Brake as well as all the guages. The entire truck is Amsoil from front to back since about 30000 miles.
We live in Goose Creek, SC just outside of Charleston, SC.
The wife and I had just left Lowe's Home Center when we came to a lite just before entering the freeway(I-26). When the lite turned green, my truck did not want to go so I got deeper into the throttle and it slugglishly moved on. But when entering the freeway, the transmission would not shift into 3rd. As I had an immediate option to exit again onto Rivers Ave, I did so. When I got off the throttle(it was wrapped to about 2700), it shifted but when I hit the throttle lightly again, it immediatly downshifted again. I tried turning the OD off but nothing changed. After exiting and at the next lite, the same thing again(sluggish). Trans tem was 150 degrees. I have never seen the temp about 170 but I have the Mag-tec pan since I got the gauges. Anyway we came directly home. The fluid is OK but appears to have bubbles in it.
Any help or advice would be appreciated. We have dealers here but if need be I would rather go aftermarket. Thanks.
