Help,
I've got auto trans problems. In drive it has no power until you get up to 30-40 mph. It won't shift until I hit 2700 rpm. It doesn't matter if I light or heavy on the accelorator. If I manually shift it from 1-2-D, it is fine.
It has set the following codes: 1693,1757 & 1762. From what I understand 1693 is generic. The 1757 means GOV pressure is not = to 15-20 PSI. The 1762 means GOV pressure offset volts too low or high. I unplugged the batteries and it keeps the same codes.
My ?s are:
1. is there anything else I can check before I take it to the dealer? If it could just be a simple sensor replacement, I'd rather do it myself.
2. If I do have to take it in, does anyone have any experience with the dealer in Lawton, OK??? I'm down here at Fort Sill for school.
I appreciate the help, I have a 1700 mile drive back to Rhode Island on the 30th.
simon
My ?s are:
simon
