Archived transmission problems
Archived Husband needs help
Archived 3rd Gear Sounds like a Huey Under the Truck
I have a 2000 dodge deisel 4wd 3/4 ton I had it rebuilt 4 months with alot of upgrades for towing and my problem came back they said the torqe converter is locking & unlocking they are going to replace the battery cables and check the grounds will this help they don`t know for sure.
The symptoms you describe are the same if a TPS needed cleaning or replacement. On the 24 valves I believe it is called a APPS (Accelerator Pedal Position Sensor).
A search should provide you with alot of info.
Here is a link to reset the APPS.
http://turbodieselregister.com/forum...highlight=apps
Don't have link on cleaning the APPS put there were many threads on cleaning the TPS.
