Well, the old truck has been having a hard time these days, and the winter was not too kind to it.
I have a rattle in the 5-speed when sitting still and in neutral with the clutch engaged. Sounds like springs rattleing or somthing. When I put in the clutch peddle, the noise goes away. This is most pronounced after a long trip of 70 miles or more. This has been going on for some time now, but is just getting worse.
Also, I have at least 1/2" or more of play in the drive shaft. I can turn it by hand either way and "clunk!". Not sure if its the Transfer case or the rear end.
I have 192,000 and everything is original in the drive line except for the Southbend Con-O clutch and Kevelar through-out bearing.
My regular maint. machanic friend says that the whole drive line is loosend up do to the power mods and probably will need to rebuild everything at some point in the near future :{
Just thinking of what it might cost for a remany 4500 with the upgrades and a NV241HD? Would Standard Transmission be the best bet? Anyone have anything good/bad to say about them? What am I looking at $$$ wise?
I gotta keep this old truck running till Dodge comes out with a 5500.
