Engine/Transmission (1998.5 - 2002) Transmission (Rear) Seal
Engine/Transmission (1998.5 - 2002) Oil Smell Until One Quart Low
Engine/Transmission (1998.5 - 2002) Check out these Fuel Pressures
My transmission yoke seal is leaking. Will the yoke just pull out of the transmission after I remove the drive shaft?
Thanks!
The seal you are talking about can be bought from any dodge dealer ship, or transmission shop for about 25 dollars. Very easy fix. If you loose a bunch of ATF out of the T case dont forget to replace it.
