transmission ?s
South Bend Clutch Vendors
MPG Loss?
My 06 needs to go in for the TSB for the 1-2 shuttle shift but this transmission just doesnt seem to want to be in the correct gears. It hangs in a higher gears then downshifts and upshifts again,light throttle sometime the tc locks and unlocks then locks again(very quickly). I dont beat it too often,occasional romp but otherwise normal driving. When flooring it it just doesnt seem to know which gear to use. Is this typical of the 48re or should I be looking at something else when I bring it in for the TSB?
I'd tell them about the problems you are experiencing so it's documented.
That way, if the TSB doesn't fix it, they can look for another issue.
