Engine/Transmission (1994 - 1998) transmission shutter
I have a 95 cummins 2500 automatic . When I drive it at about 50-60 mpr the rpm go's from 1500 to1700-1800 in and out. Around 50mpr if you give it a little gas the tork converter will start shuttering if you give it more gas it will stop shuttering . I have had it to two transmission shops and one said it was the computer the other said it needed valve body and a better tork converter? what should I do?
I had similar problems.
Following advice on this forum i cleaned my battery terminals..... no joke my problem went away. It will still shudder with too much throttle during that shift into overdrive.
KRStone thanks very much. I'm new to all of this but I did go back in the pages and fond a lot of good information on it . thanks
