Transmission "stutter" on downshift
2017 Water pump does have a weep hole
I have a 2014 Ram 3500 Diesel and love it for hauling my truck camper.
This winter, with camper off, I have noticed a persistent "stutter" on the downshift when I release the accelerator and coast.
It creates a small shudder.
I have not noticed any hesitation on acceleration - only the hesitation when the pedal is let off.
Any thoughts / comments?
Thanks
Stephen
It's probably normal ... my truck does different things depending on if it has a load in the box or not. I would crawl underneath and look for obvious things, worn u-joint or steady bearing (if equipped).
Thanks, I will check into that - the forum members here are WAY more mechanically inclined by me, but I am pretty sure I can figure it out.
There have been many software updates for shift improvements.Fluid quality will also have an affect on shudders
The trans will not downshift (on a coastdown) until you've slowed down quite a bit. Is your "shudder" right when you release the throttle? If so, I doubt it's trans-related. If it occurs later (when the trans actually downshifts), which particular shift is it? I believe that from 4th gear it will downshift 4-3-1 as you come to a stop. From 5th gear, 5-3-1. From 6th gear, I don't recall offhand whether it's 6-5-3-1 or 6-4-3-1.
