yycguy said:For the 48RE what is considered a temperature to start worrying about when towing? IE what should we never exceed?
TWest said:Normal operating 140 to 180 , 190 Ok , 200 Get out of it, 220 backoff, 230 do immediate fluid change, 240 get check book out, 250 start to right out check,260 to 280 write out second check for Tow charge. Always try and remember that these are temps at the sensor ,You could be a easy 100 plus in the TC if you drop out of lockup and start to pull with fluid coupling.
MDW said:Lock the converter and keep the rpm's up.
PScheren said:Everything above sounds like good advice, but sometimes hard to do. Towing a 10K trailer up the 20-30 MPH. 5 miles of steep switchbacks into Black Rock Canyon of Gunnison and Colorado National Monument, I saw my temps approach 225 at the top. There is no place to stop on the way up.
PScheren said:I dropped it in 2nd occasionally, but not consistently as I was under the impression that it would keep it locked up if you were locked prior. I didn't think or know that dropping it would initiate a lockup under 48 mph. But I could be wrong.
dmbarker said:I have the new isspro gauges, and see temps at 200 in stop and go traffic with out towing anything. Out side temp is averaging 93 degrees. My gauge temp sensor is in the side of the transmission pan as described in the TDR magazine a couple of issues back. Is the temps I'm seeing normal? I also would like to hear if anyone knows what the stock transmission idiot light goes off at?
