"Mad Max"
matching a 47RH converter to an early VE44 6BT
fellas I got a question
I'm doing a diesel conversion on my '93 Ramcharger 4x4 LE; installing an intercooled '91 6BT, a 2nd gen 47RH, and a 241 t-case, D60/D70. Going to be a daily-driver, not a serious tug boat.
Like all early 6BTs with VE44s, the operating range is basically from 1200-2000 rpm, and the aftermarket A518 converters are designed to hit that rpm range. But I'm not familiar with the 2nd gen converters and their operating range. I presume the normal range is higher? Can you give me the 'range'?
I was planning to install the tranns as-is for now (so long as it get's me through the winter - I'll rebuild it later), but the more I think about it the more I'm concerned that the stock converter will not be 'matched' to the '91 engine. Can anyone confirm that? I'll get a fresh low-stall "1st gen" 47RH converter if necessary - I'm just trying to determine if it's necessary before I try to drive away.
Thoughts?
Many thanks,
- Sam
Thoughts?
Many thanks,
- Sam
