I am having a problem with my 98 12v. Truck is running great just no reverse, it sounds and feels like it is shifting into reverse but just revs as if in neutral. I had it towed home and checked the codes and here is what I got.
P0123 TPS High Voltage (Which I expected been surging in overdrive)
P0401 Insufficent EGR Flow (Also expected since I removed EGR)
P0118 Engine Coolant Temp Circuit High
P0113 Intake Air Temp Circuit High
P1763 Governor Pressure Sensor High
I cleared all codes and took it for a drive and the only code that returned was P0123 TPS high Voltage.
There is also no engine braking in 2nd gear which would indicate a broken band, but when I downshift into 2nd you get a quick rise in RPM then back to as if in neutral.
I am off to drop the pan and see what I find. Any ideas or suggestions would be fantastic.
