I have read a lot of previous posts about transmissions and think I understand what I need but would like to ask anyway.
91,000 highway miles with stock motor and very little towing of light trailers (6500 lbs). Trans fluid and filter were clean at 90,000 mile top down fluid/filter change. Seems to be just fine. Plan on adding an edge and RV 275 injectors soon. I want to be proactive and upgrade the transmission first. Like the DTT setup but wonder if just a converter and valve body will do the trick or if more extensive mods would be needed. Would rather spend a little more and only do the job once but don't like throwing money away when I have a perfectly good transmission now. Also I have had bad luck with Auto trannies in the past so I would like to have someone else do the work. I live about 1 hour from York PA and Baltimore MD. Are there any recomended shops in the general area. Not dead set on DTT either am open to other suggestions. Hope this doesn't cause trouble. I need to upgrade soon because my Brother in law just bought a Dura max and needs humbling.
Thanks
Thanks
