Before considering replacing OD solenoid and wiring harness, wire a mystery switch into the OD circuit and verify that mechanically things are functioning. Seldom is the solenoid or harness a problem, it is almost always an electrical glitch somewhere as OD is purely under computer control.
Validating mechanical operation will save you headaches and $$.
Typically intermittent OD can be traced back to gov pressure transducer and solenoid and\or the output shaft speed sensor, or, connection problems. Change out those 3 and go from that point.
