Ive held out long enough ... LOL
This is the first winter for the 5. 0 Kick down , the SC triple and SC HD VB , And when its cold out and the truck is below operating temp and I put it in Drive it Die's
If I stop at "R" for about 30 seconds then put it in "D" it helps but has still died . .
I have remote start ,,,,, the truck wont die going into "R" but it does bog down ...
With the remote start it helps to have it a little warm before you get out there but it has still dies after 10 Mins Warm up .
Called my transmission shop and told them I think my pressures are TOO HIGH .
Going to drop it off TUES PM and will find out WEDS what they found out ...
May have to drop out the Sun Coast VB and turn it to a more reasonable Pressure level as when it shifts now IT DONT MESS AROUND
But in colder weather its a PITA .
Another plan of attack I had was to get the cold weather Reflash on the ECM to up my idle RPM ,,,,, This would Mask the isssue but not fix it .
Lets see how much $$$ this is going to cost
New Rims And Tires are suppose to be here Wed or Thurs Hope I have a truck to put them on
:-laf
DM
:-laf
DM
