transmission
South Bend Clutch is in.
thread updates?
starring
i have a '95 2500 with 114,000 miles. I just replaced the throttle positon sensor to attempt and solve my transmission problem. The trany shifts better, but it still gets hung up. I am also still having problems with keeping my cruise control working. whenevery i go over any bumps it will disengage. any ideas?
I've seen a few trucks that kicked out of cruise when hitting a bump. It was the brake pedal bouncing and turning the stop lights on briefly.
Can you describe your transmission problems more? Which gears? What do you mean by hung up?
-Chris
I kept jumping out of cruise also and found the control panel on the steering wheel was dirty. Blasted it real good with an air line and now it works great. Blast it out every so often.
