Engine/Transmission (1994 - 1998) Transmisson not going into 1st gear when I down shift!
Engine/Transmission (1994 - 1998) Upping timing just a little.
2nd Gen Non-Engine/Transmission 2003 rims on 2002 ???
I just recently put a ats diesel transmission in my truck and I absolutly love it. I have a problem with the transmission not wanting to shift into first when it gets hot! Does any body know what the problem could be also I am running right around 80 psi in the lines at idle!
Are you saying it doesn't downshift when you manually select 1st, or is it taking off in 2nd gear because it doesn't shift into 1st on its own?
when i got my DTT trannie i noticed something simmaler when i was down shfting. if i manually selected 2nd it wouldnt shift there till about 30-35mph. and 1st gear till 15mph i belive. if i put it in OD Off then 2nd it would shift into second and then 1st it would also. but OD off has to be selected.
