I'd check the kickdown/throttle valve cable and make sure it isn't broken, disconnected, or way out of adjustment. If that checks out okay there is probably an internal problem, and will probably require taking it to a transmission shop. Stick to a locally owned, independent shop instead of the chain stores - you'll get a much better job at a better price.
