The front end has been apart before and I covered everything in Never Seez.
In spite of that both rotors were stuck on, had to heat and beat, heat and beat, etc. I could see the ring of Never Seez where the hub meets the rotor but they were still stuck.
Pretty quick after the first couple of sessions the big chunks of rust starting falling out.....what had happened was the inside of the rotor had rusted and trapped the outside flange of the hub behind the rust. don't recall ever seeing that before.....
Had to take a chisel to the rotor and clean the rust off.. Now that area is all silver too....![]()
Yo Hoot;243858 I use a grinder with a cutoff wheel to take the old joints out. Friend of mine showed me and it's a lot easier plus you don't beat your yokes and bend them in the process. [url said:https://youtu.be/XGUqAp6Q6WY[/url]
I've used a smokewrench many times.... just be fast and don't let the yokes get hot!! The '03+ Dodge with the AAM U-joints in the rear shaft almost always has to be cut.
As for amount of grease in the U-joint, in most the joints I've installed, there are cross tubes from one side to the other. I fill those and the caps, then by force they top themselves off and squeeze any extra out the seal. Centrifugal force makes sure the amounts are even across the tubes, and the outer needle bearings get their share. I am unaware of any specifications from Spicer or anyone else on amount of grease in the units themselves.
The ones I got had a little note in the box that said not to mix the caps.
Just getting back from picking up new glasses, making the jump from bi-focals to progressive lenses. Let's see how this works when trying to hit something........![]()
Mike
Took me a long time to figure out why I was having issure backing up with glasses ( had chocked it up to old age lol). Here is the issue, progressives do not allow a focused pheriferal vision ....If you look out of the corner of your eyes left or right , in the mirrors you get a slightly distorted view. If you fully turn your head and look straight at the mirror it is much better but very difficult to break old way (pre glasses).
What worked for me was getting a set of bifocals and keeping them in the truck just for backing trailers (problem solved).
Just one more thing to look forward to as we age. lol
