Triple Dog question
BD valve body nightmare
stacking quad XZT with ?
Does the Bully Dog down-loader boost fuel pressure to the injectors? :confused:
I'm interested in this product if it isn't a pressure box.
According to their techs, the downloader uses timing/duration stretch on the two lower settings. It only increases rail pressure on Extreme or Crazy Larry. I've been running it for a while now, and it does not give me the impression that there's any pressure.
I did run a pressure box (Quad Race) for a while, and on the higher settings, the injectors would rattle/knock when coming back to idle from a full-throttle run. I believe that was residual high pressure bleeding off, but I'm not a tech, I can't be sure.
TWest said:
Yes it does, Not Much 1/2k,With your Ring mod it may cause problems.
I went and had the demo program installed. They put it on the lowest setting and it lasts for 4 days.
I like what it does for the truck, but at idle I am getting a high pitched, tinney, knocking noise :confused: Anyone know what this could be?
When you use the Master down loader the version it loads is not the same as the T-Dog,Hopefully they have update the Master down loader with the current version,Go back and have them return it to stock, also find out what level was loaded,Their are many accessories store selling the down loader that don"t NO anything about Performance/electronic and have cause several re-flash to be done. One customer lost his cruise, another lost his wiper control,etc, all relate to the poor operation of the Master down loader, NOT the Program.
