I know SunCoast makes more than one level of fluid efficiency. Saying a SunCoast converter is not efficient or even as efficient as their competition is just not a correct statement. That depends entirely on what you buy from them. I don't like smoke unless I want it.
If I have a 91 or 93% efficient converter, how will it do for temps while idling in traffic? I believe this is one of the reasons the factory unit is so sloppy, to keep temps down. Every tight converter of ANY brand I have seen get hot when sitting still in gear, like in traffic. For everyday I want a balance of efficiency for movement vs rpm. Especially with a 12v. Again a balance is what you look for related to your driving style and needs IMO.
In January I did a test. Dyno'd a stock TC in a 350hp truck. Replaced the TC with a Triple Lock. Expected to see a power loss as I was one that figured the weight would take power. I was surprised, It did not!!! Same power output.
My 12v at 69XX pounds runs 13. 80's here in Atlanta at 430hp, wastegated down to 60 psi boost max. It towed the Garmon Dakota with an estimated total weight (Dakota/trailer) of 7-8k pounds. After 50k miles of this type of work (105k total) including daily traffic, the transmission looked great upon inspection.
Take a 6200 pound truck from 0 - 102 mph in 7 seconds. That is Matt's and Darrens 1/8mile. That is hard on EVERYTHING including the transmission. Jeff runs 1. 4's - 1. 5's sixty foot times. Seen lots of tire shake at times, no breakage. Yes I am talking racing, but racing IS what helps develop products. If it will live in the above conditions, it should live in an easier environment.
So why did I choose what I chose?
1) When you hang around a shop that has been beating on transmission parts since way before you could log onto the internet and talk about it, that currently builds some of the fastest trucks in the country and rarely see a failure since using this product, it's hard to ignore that fact.
2) Because I fortunately had the opportunity to drive many trucks equipped very differently and learned of the ups/downs of each approach for my likeness before I bought.
3) Based on #2 I wanted better than stock fluid coupling but less than some of the "more efficient" units because I was worried about heat in traffic and I wanted more control over the smoke.
4) Wanted strong lock-up and watching Jeff for years lock up as soon as he launches told me this converter was tough.
5) Solid warranty.
I have a Sun Coast 44
They are all good units and light years ahead of a stock unit. If you can, test drive one like you "think" you want in similar conditions as to what you will be in. If it is what you want, buy it. If not, move on to the next. Make sure you compare the same type of truck as the one you have too. In 2000, the Dodge started to lock in 3rd gear. Not so in the earlier 24v's. And the 12v's are a different story all together.
And Smoop - 123. 6 at 7000 pounds comes to 885. 8hp.
And lets add ol' Bill Fletcher to the hauling a$$ and kicking gas 10 second Sun Coast crew.
