Triple stack too much?
What is out there for the 06's
Power Box Info Needed
Thanks to BigBadDodge and Brad from dynotuning.com. I had a blast yesterday making 526/912.
The hp number pleased me, but the box settings kind of surprised me.
I have been reading and listening to TDR members about box settings when putting our trucks on a dyno. It seems that anything over 7x7 on the TST only yields smoke and high egts, so that's what I went with. The variables in my dyno runs were the TS Ramifier and the Bully Dog Triple Dog.
First dyno run: TST 7x7, Ramifier 40%, BDDL on "stock" = 508/886 :)
Wanting more, of course, I changed settings.
Second dyno run: TST 7x7, Ramifier 40%, BDDL on "tow" = 422/766 :confused:
Third dyno run: TST 7x7, Ramifier 0%, BDDL on "tow" = 526/912 Oo.
I was really surprised at the 86 hp loss using all three boxes. I got the best numbers w/o using pressure at all (BDDL "tow setting" is timing/duration only).
I'll be sending in my TST for the Twins flash and the Ramifier in for a programming update, and hopefully someone will have a dyno soon so I can play some more with the settings.
Anyone care to report their settings for best power gains?
BDDL on "tow", VA C3. 1 on 100%, TST on 5x2 netted me 641. 8 hp and 1230 tq. 7x7 is more than likely draining your rail. I stepped mine up to PL 7 and dropped over 130 hp while egt's went thru the roof. Drop the TE level way down and start at a much lower PL number on the TST. Then work your way up with the HP setting only until the power starts to fall off. This system will get you higher numbers for sure.
With mods in my Signature TST w/Twins 7/7 and EZ stacked on Level 3 dyno'd 503rwhp. Anything higher on TST just lost hp. Probably CP3 issue from what I can determine from other posts and talking with performance gurus.
With TST 7/7, EZ Level 2 and BD Triple Dog Performance program dyno'd 522/930. Any higher TST or EZ lost hp. TST 7/8 with same combo raised torque to about 950, but dropped hp. Still think limits are at the CP3, just dont have tools to tune this with yet.
I run my rig w/tst std box on 3/3 and 4/3, my ez on level 3, and my xcellerator programmer on extreme and I get awesome runs, but have not dynoed yet
Since The Injectors, Sop Says 4x3 Max Tst, No Ramifier Yet But It Is Coming As Soon As I Get The Snow On , Anything Higher And The Pressure Falls Off Fast,and The Pyro Picks Up Faster Than The Speedometer... .
