Hey Guys,
Lately I here found that my volt meter has had erratic readings. Today my volt meter read unusually low (at and below the dash line just left of center) and after checking the rest of my stock gauges I noticed the oil pressure was unusually high (just past the dash line right of center) and temperature gauge was reading warmer than normal. The weird part is that as the volt meter occasionally went to back to normal, for a short time, so would the other three gauges. This kind of freaked me out so I went to the local Schucks and had the voltage system checked, all is good. I then checked my oil, the level was normal. Now all that being said, after having my valves adjusted by Cummins Northwest about a month ago, they had noticed that I too was in need of a new belt tensioner relatively soon (original tensioner w/ 190,000 mi. ). Since then I have been keeping an eye on it and I have noticed that while the truck is running it does dance and jiggle more than Jennifer Lopez. As well, the belt is riding about a 1/4" off the pulley toward the tensioner arm. Could these two things be related? Could a loose belt cause my gauges to go awry, do to a lack of tension on the alternator? I checked thread achieves, I couldn’t find a similar experience. I did buy a new Dayco belt tensioner ($100) which I will be installing tomorrow for preventive maintenance. So I guess I will see what happens, but what do you guys think?
