trouble code 0088
AeroTurbine or No AeroTurbine
Erratic idoling
I think a clogged fuel filter would be the opposite, rail pressure too low. Any mods on the truck? Most boxes raise the rail pressure to gain HP. If it is really stock I would think you want it looked at as too high a pressure will blow the relief valve and get ugly!
Could a lift pump pressure surge cause an injector pump pressure surge to trip the code? The driver stated he started the truck quicky turning the key directly from OFF to RUN.
