Archived Truck broke down in Middletown Va.
Archived Truck will not start
Archived 2nd lift pump and hard starting is back
Yes, truck is down. On my way to florida and made it 1/3 the way.
Broke an injection line coming off the vp44.
Anyone around here know where I can get a new injection line?
Checked into a motel 8. Looking for help.
Did you check the Travel Companion? The time I needed help in VA a member from Newport News helped me out.
Don't have a paper copy of the companion.
I'm doing this through my Iphone which can't see PDF files ( which the companion is in. Hotel has no computer.
Mactruck called this morning. He rented a car to go to the Cummins store, got his part ((injector line)) and is back on the road running good.
Good Luck
Cliff
For next time the travel companion isn't only in pdf format on here. If you go to the travel companion you can do a search by state, etc and get results showing all the entries. The PDF is only if you want to download the entire travel companion. You can get names, numbers, etc from any internet connection without having to read pdf files.
Glad he got back on the road.
