Rock-I agree with you big time on the tires being the limiting factor when talking loads, that's why my 97 ford F-350 SRW went away. The 7,500 lb rating you came up with is for the entire stack of springs. When I replaced the factory "overloads" I gained 3,500 pounds additionally to the stack ratings. When considering the loss of the original overloads to that 7,500 lb rating it is very minimal. I mean you can grab those factory top 2 leaves and move them by hand??? How heavy duty are can this be? When I originally bought my Lance 9' 10" I thought my F-350 could handle the load, Wrong. The rear bumper was almost on the ground and the tires buldged badly w/ psi's up to max. I put airbags on which helped with the leveling but they inhibited axle travel, especially when empty. With the minimum air pressure in the bags it was nasty riding in the truck on unpaved roads or rough roads. That's not to mention the leaking problems. The ford went away,-way to much money to convert to dually. $4,000 - $5,000 to do it right. It was all a learning experience for the good. I now have Dodges that I love. One thing I do recommend, If you get the springs done save the old rubberband factory "camper package springs" that way if you ever want to switch back you can for any reason, they are easy enough to change.
