Hi guys,
Been awhile since I have posted due to a move and new job, have missed it.
I would appreciate any help/advice on a problem I'm having with my 2002 HO 6spd.
While cruising the power seems to cut out for a second or two causing the truck to feel like I'm pushing and letting off on the throttle. My wife actually thought that is what I was doing. It isn't noticeable while accelerating but very noticeable while cruising in 3rd, 4th gear. It is worse in the morning while it's cold but still does it in the afternoon when it's warmer. Truck only has 30,000 miles on it. Checked the fuel pressure today and it was around 12psi while cruising and around 5psi at WOT. Still on the stock lift pump. Codes show P PCU 1693 & P ECU 0216.
Any idea's on what to look at?
Also, is the lift pump and injection pump covered on the Cummins 7 year 100,000 warranty?
Thanks a million,
Ray
Thanks a million,
Ray
