Hmmm... truck stumbled and died on the way to work.
It died similarly about a year ago and it was the poor COMP tap to the injection pump. So I temporarily repaired it with a crimp-on butt connector (and never got around to permanently repairing it). Last month it died and I assumed it was that it lost contact at the butt-connector - wiggled it to get a fresh contact and it started right up. So today I soldered it, but it still won't start. Codes 1693, 1694, 1689, and 0237 (have a boost sensor issue also). 1694 would seem to indicate lost signal to injection pump.
Here's the odd parts: The "wait to start light" is acting strange - sometimes extinguishes right after key on, sometimes comes on while cranking, sometimes seems normal. Also, the tach and oil pressure gauges occasionally stay high after a no-start when the key is left in the on position.
I soldered in about a foot of extra wire - could that be an issue to the injection pump signal? Or does it sound like ECM? Lift pump sounds to be working, though I have to go check flow. Just not sure that is the problem and looking for thoughts - thanks.
