On my way home tonight the truck died about 1 mile from my house. I have a Edge Comp and decided to give it a try on 5-1. I was in an area where the speed limit went from 40 to 55 so I went WOT for about 1/8 mile. The truck pulled well, but when I lifted the pedal it decelerated, but then kept slowing down. It is acting like a gas truck that has no spark. Fuel pressure is good, it never fell below 10psi. Boost never went over 28. When I crank it over, fuel pressure jumps around a bit from about 13 down to 11 but the engine won't turn over, just keeps on cranking.
The truck is stock except for the Comp box that I always run on setting 1-5, this is the second time I've tried it on higher settings, this time it didn't do so well.
Let me know what I should try doing.
Nate
Nate
