VP44 is Toast
F-15I Ra'am; It's dead dude!!!
My truck, a 2000 QC Auto. did the same thing on Wednesday morning on the way to work. Accelerating away from a stop sign, it died as if you has shut off the ignition.
Got the P1693 code flashing the key.
Call the CT Coffee Night bunch and they said it's the VP44.
Called my local Diesel Guru, and he said it sounds like the VP44 also, however try the Crank Position Sensor.
Well, I changed the CPS, No small job due to it being behind the starter, and it's bore had a layer of rust in it. Hook up the Batterys and I did a quick APS reset, Nothing!! Cranks, but no run.
Have it towed to the Guru's shop, get a call a couple of hours later, VP44 rotor had sheared off. :{ Got to do some creative financing now; $1450. 00 Please. There goes the Rip's 4" Dual Exhaust, the Westach Gauges, The FASS pump and finishing the Veggie Tank. Sigh, and end of Rant.
The P1693 is a code for "P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine control module.
P1693 (M) DTC Detected in PCM/ECM or DTC Detected in ECM
A 9Companion DTC9 was set in both the ECM and PCM. "
This means the Engine Control Module is sending a Diagnostic Trouble Code to the Dodge Powertrain Control Module, that the PCU Does not understand. This P1693 is quite common and is even known as that "Companion Code". My Guru has all the computer stuff that can talk to the ECU and that's how he found the Rotor Failure.
Moose00 Oo.
