Engine/Transmission (1994 - 1998) Truck dies when I hit hard bumps in road
I have a 97 with twin turbo,370 inject,race fuel plate,water/meth,5inch exhaust. when driving on a dirt road or paved that is very rough my cummins will die after I hitting hard bumps, but will start right back up! I think the fuel pump is going out or not :confused:
Wire your fuel solenoid up and see if it still does it. Something might be wrong in your solenoid circuit that's letting it drop a little when you hit a bump. A part might be failing or just a bad connection causing it to loose power for a second. Might be something else too I don't know but it's an easy place to start.
was gunna say the same thing. sounds like a shut off solenoid problem.
Wow, with that much juice, I would be a little perturbed to lose power just cause you hit a bump while smoking a ricer!!
I had the same problem last fall. I tightened the wire connections to fuel shut-off solenoid first and eventually replaced the solenoid and have not had the problem since.
