Its about zero degrees here in Anchorage and I,m developing a new problem. With the engine Hot I put it in Drive and it dies. Idle is at 775 rpm in neutral and of course pulls down when in gear. It does not do this all the time but is becoming more frequent. Also does it when the exhaust brake is engaged in neutral. Rpm,s with brake on are 675 and pulls way down to 500 rpm,s when initially engaged. Also the governor ?? sometimes makes the truck rev up and down when putting in gear as the truck trys to compensate for the load. What do you think ? a ba d TPS ? Thanks
