I've been having a problem for the past month or so. What happens is that the Edge Comp box (re-branded by BD) will lock up (none of the buttons do anything) and I will loose power. At times the engine will actually shut off and the Check Engine light will come on. Sometimes the box won't even come on when I start the truck. It always comes back on and runs fine when I turn the key off and then back on. Eventually it will lock up again; maybe 5 min. or maybe 5 days. I have a direct ground to battery and have re-wired the power to a aux fuse box I installed. Everything else doesn't loose power, so I don't think it's power.
When the box locks up it will turn all the lights off, leave them on like normal, or turn on / off random lights.
I have pulled the codes and get 0251, 0252, and 0252. So is it the pump or the box? What can I do to check it out?
