rncordy
My 2010 (see below) has performed almost flawlessly for over 5 years and 107,000 miles. But yesterday, with a temperature of about 45F, it balked at starting, but did. It didn't sound like a low/weak battery, just wouldn't crank and made weird clicking sounds, and the windshield wipers turned on! (I thought I had left them on from the rainy day before.) I then backed off the ignition switch and tried again and it cranked over and finally started. It ran fine, and restarted fine, the rest of the day. Except it continually showed on the Trailer Brake Controller a fault code of "CF" and showed the red icon for the trailer not being connected (and it wasn't).
Today, the same start up procedure occurred, with wipers coming on even though they were not turned on, with the added mystery of the radio failing to find any stations on Satelliite (and the HDD music would not play). WEIRD.
Do you think a low/weak battery could do this, or is it most likely a bad computer somewhere between the bumpers?
Thanks for your thoughts!
I'm leaving it on a trickle charger tonight to see if that changes things in the AM.
Bob
Bob
