Sitting @ McDonalds Drive thru this morning with heater and headlights on the motor kept on bogging down like they do when you first start it not sure what thats from I think its where its charging the batterys Im not sure on that. the thing is it kept doing it over and over and over I looked at the Ampres and it was loosing charge then bogging down then ideling right for about 5 sec then bam the amp meter would fly down to about 12 then the motor would bog down then the gauge would return to normal about 15 like I said it just kept doing it????
I turnt the heater off... ... no help
I turnt the head lights off... . no help
I gave it some fuel and ran 1500 rpm for about 30 sec... . it continued to do it at an idle
I had the comp on 2x2 I tuned it off and it charged up to 15 and stayed there!!!!?????????!!!!!!!!!????????
PLease Dont tell me My comp is screwing my truck up again... . loose connection crap ... . bad ground mumbo jumbo that gets old after reconnecting every thing 50 times!!!!!!!my connections are fine if the comps going to be so stinkin picky about its connections maybe it should be upgraded .
I turned the comp back on and everything was fine the truck held charge... .
Has anybody had this problem ???? Is it comp related ????or just a ca-win-ci-dence ??? OK I cant spell it
DM
DM
