Competition Truck Pull in KY
Competition First Western TDR Sled Pull
Competition Thunder Truck Drags
There will be a Diesel Truck Pull in Shelbyville, Ky on May 25 and the rain date is May 26 Will post more when I get the paper back from being passed around
Have you got nitrous or propane? The last time I saw one of your sigs, you were running close to what I had- H2E, Mitchell delivery valves, Mitchell injectors, Gov. spring kit, #4 plate, maybe a gutted AFC housing. By now you probably have the cam and pistons in that you were thinking about getting. Was it you that Piers was building the pump for? Yeah, they probably have a class for you. I pulled with Dave Mitchell and Dave Gresh last year. Gresh pulled at Shelbyville last year and I pulled with him. He lost the rearend in his and I burnt the clutch completely out. We were the only really bad smoker trucks there last year at that pull and neither one of us took home a trophy. :rolleyes: I've retired my truck for now. I have to start saving to get married. Gotta sacrifice something. I've pulled a smoker truck for about the last two years and became known well enough as "that silver Dodge", that know; when I show up, the local yocals won't let me pull. Plus I can't afford a cam, twins, lower comp pistons, o-ringed block, 5500rpm 13mm+ pump, ARB locker for the front, marine head, block reinforcements, etc. It's expensive; I've checked on it all and I'll keep on dreaming. If you decide to come and are taking I-75, let me know. I live in London, KY and I am going to go watch. We might be able to go up together.
HOLD IT!
"block reinforcements"
That is not on my bill, should I have gotten that?:confused:
Gene,
I heard that on your ticket it said, "Payment is to begain as soon as you bend over!" ;)
I also heard you refused so they sent the law after you. :p :D
Just kidding ya,
Andrew
It wouldn't really be block reinforcements I don't guess. Scheid has some better hardware for the bottom end. I also thought about filling the block and only cooling the head.
there is also a pull in Bardstown. KY. july 19. there will be 2 classes street and open. you can see classes and payout on the calander of events or call 502-349-9493.
Studding the main caps and head works also. The reason my truck is not allowed to pull, is that for some reason Open has to be street legal. Mine's No where near there. I'm not runnig propane. Yes Piers is building a pump for me. My Six, that's just water weight gain, it will go away, Really:D :D
Don
Don,
Isn't your truck licensed and insured? This is considered street legal for most pulls. Almost everyone knows which trucks are hauled in but they don't care because they know it is an open class. Granted that they probably would buck if you had your motor in the bed or cab, a center drivers seat, or all fiberglass body. Mitchell and Gresh would pull if it was open and everyone knows that they are trailered trucks. They won't stop you from pulling as long as you have proof of insurance and registration.
Smoker, no my truck is not licensed or insured to run on the street. It has been built as a pulling truck. there is nothing on the truck accept what is needed to pass the safety inspection of the organization I pull with here in MO. These rules include engine side guards,Harmonic balancer guards ,driveshaft loops, u-joint shields and air supply shutoff devices, just to name a few of the requirements.
Don
not allowed?
you guys will have to check and make sure but i think that they are having a class that you can run in. kind of like the only rual is "NO WHINING":D i will post if and when i find out for sure>
check this out and see if this answers your questions. i don't pull but here are the rules for shelbyville. FIRST ANNUAL
WORLD CHAMPIONSHIP DIESEL
TRUCK PULL
Sponsored by the Shelby Co. A&M
Held at the Shelby county fair grounds in Shelbyville, Ky.
Saturday May 25th. Pull starts at 3pm, weigh in at 1pm. Raindate the 26th.
Classes Payout
6200 lb. Gas daily driven trucks $ 250, 150, 75, 50, 25, 25
7500 lb. Diesel daily driven trucks $ 250, 150, 75, 50, 25, 25
8800 lb. Diesel daily driven trucks $ 250, 150, 75, 50, 25, 25
8000 lb. Diesel Open trucks $ 500, 300, 150, 75, 25, 25
Hook fee $25
RULES
6200lb. Gas daily driven trucks
1. Trucks must be driven to the pull unless from more than 50 miles away.
2. Trucks must have factory frame and body. No fiberglass weight saving sheetmetal or homemade frames.
3. Truck must have visible VIN number that matches that on the registration and insurance. Proof of registration and insurance will be required. License plate must be affixed to the truck.
4. Engine is limited to one 750-cfm carburetor, or factory fuel injection. Must be O. E. M. engine appropriate for the truck. No alcohol, nitrous or water injection. Gasoline is the only fuel permitted.
5. No solid suspensions. Must have at least one inch of suspension travel.
6. 26" hitch height, pulled from bumper or receiver style hitch only. The hitch point must be the furthest point to the back of the truck.
7. D. O. T. street legal tires only. No bar, cut, or altered tires. No tire chains or studs.
8. No hanging weight. Bumpers must be factory style, no substantially, (50+lb), weight adding front devices are permitted. Store bought brush guards are allowed. Weights allowed only in cab or bed of truck.
9. Driver must adhere to the flagman, or will be disqualified.
10. Judges may prohibit any vehicle from pulling that is deemed unsafe.
7500lb. Diesel daily driven and 8800lb. Diesel daily driven truck
4. Engine is limited to one turbo with a maximum of a 4-inch exhaust turbine outlet. No alcohol or water injection.
9. The heavy weight class will be based on the heaviest truck in the class, but will never exceed 8800lb.
10. Driver must adhere to the flagman, or will be disqualified.
11. Judges may prohibit any vehicle from pulling that is deemed unsafe.
8000lb. Diesel open
1. Trucks must have factory frame and body. No fiberglass weight saving sheetmetal or homemade frames.
2. Truck must have visible VIN number.
4. Engine must be diesel, anything else goes. After all it is "open"
5. 26" hitch height, pulled from bumper or receiver style hitch only. The hitch point must be the furthest point to the back of the truck.
6. Axles must be appropriate for the truck, no two-ton truck axles allowed.
8. Driver must adhere to the flagman, or will be disqualified.
9. Judges may prohibit any vehicle from pulling that is deemed unsafe.
10. Scatter shields and blankets are strongly urged, but not required, unless the vehicle is turning in excess of 5000rpm.
Judges Decisions are Final!!!
No whining or arguing!!!! Contact Ray Tucker (502) 419-8842
6200 LB. GAS DAILY DRIVEN $250,150,75,50,25,25
7500LB. DIESEL DAILY DRIVEN $250,150,75,50,25,25
8800LB. DIESEL DAILY DRIVEN $250,150,75,50,25,25
8800LB. DIESEL OPEN $500,300,150,75,25,25
Location: Shelby Co. Fair Grounds Pull starts 3pm. Rain Day 5/26/02 Contact: Ray Tucker 502-419-8842
