Truck Pull in Loveland, CO
Mud Bog Shoot out & Burnout Contest
NW BOMBers
Just found out about a pull in Loveland this weekend, June 23 & 24. It will be behind the Loveland Auto Auction off Hwy 34 and Denver Ave. There should be signs showing the way. Registration is 8:00 to 10:00 each morning with pulls starting at 10:00. Looks like about $20. 00 per pull. From what I can tell diesels, V10s, and all duallies will pull on Sunday. Should be a good time even if you're not pulling.
joesoot - you need a clevisapproved by the safety team and there is a 28" maximum hookup height for all vehicles. Just so you know the pull is in memory of John French and put on by the Big Thompson 4-Wheelers.
Dave
Class 5 - 125 to 135 inch wheelbase and 6500 lbs weight limit
Class 6 - 136 to 148 inch wheelbase and 6500 lbs weight limit
Class 7 - 149 to 170 inch wheelbase and 7000 lbs weight limit
Besides the duallies (class 8 no weight limit, gas and diesel) these are the only classes for diesels and V10s.
Rigs are weighed immediately after they pull
