Could it be that all of these things or any one of these things may send the truck into the wobble? I tend to think that the front ends on our trucks are not the best engineered systems on the vehicle. I've heard it said that the fronts are built 'out of geometry. ' I'm not real sure what was meant by that, but I would agree that several things aren't up to snuff. The drag link/tie rod connection: I would much rather have the drag link attached to the RH knuckle on top and the tie rod on the bottom instead of the funky meet in the middle deal. The trac bar: that's been well covered, it sucks. The steering stabilizer: looks like it's not in the best position to absorb shocks to the steering linkage to me. The sway bar: I don't like the long linkage and bracketry that holds my '96 together. So, IMO, there are quite a few components within the steering system that may lead to bad performance.
Now then, in my case, I have to agree with JWEST and Dane. Uneven tire wear and mostly worn out tires caused my wobbling. I had a DT trac bar with the replaceable end in good shape, Bilstein shocks, and a brand new Heckthorne stabilizer. I also had over 85k trouble-free miles behind me when I had my first wobble. I've had it two more times as I'm still on the fence about what tires I'll try next. I fully expect my wobbling days will be over upon tire replacement.
What I'm getting at, unfortunately, is that I don't think any one of you can tell me I'm wrong and I, likewise, cannot tell you you're wrong. I wish it was that easy, but I've researched this a fair amount and there are too many cases with too many solutions to say it IS this or it IS that. All the tips and solutions offered here are solid and worthwhile efforts to investigate, but don't be surprised if it takes a few tries to eliminate the problem.
Yes, my confidence at speed has been permanently rattled. I have a 3kGSK sitting on my bench and all I can think is 'Why in the hell would you want more? Can I trade it for a 2kGSK?' Good luck wobblers.
